85 Gleaner N5 header won't lower.
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: 85 Gleaner N5 header won't lower.
    Posted: 08 Apr 2017 at 3:14pm
As the title says my header won't lower, it raises fine, fluid level is fine, where should I start looking for the problem at? Thanks.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 6:13pm
Possibly oil pressure sending unit. It won't lower if it doesn't sense pressure. Should have 2, try swapping them if gauge works.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 7:31pm
Actually,there are three engine oil pressure sending units. One is larger than the other two and has a single wire on it. That one operates the gauge. One of the small ones also has a single wire and it is for the red idiot light. The other small one has two terminals and the wires are yellow with a black or red stripe, can't remember the color of the stripe for sure. If you suspect that switch,just hook the wires together and then try it. You could also switch the raise and lower wires at the valve stack and see if it will then lower by pushing the raise side of the switch in the cab. If it still won't lower when you have 12 volts at the lower solenoid coil,you could have a bad coil or a hydraulic problem. Good coils when energized, magnetize the end where the nut holds it on. A small screwdriver or knife blade will tell if it's magnetized. It also has to ground through the gold colored canister. Switching the raise and lower coils is another test you can try . I hope that the ram stop is up isn't it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:52pm
First thing to check is with a test light, check for current to lower solenoid  while some one is in cab with motor running. If no current, follow wire up to oil pressure safety switch. If no current there go to lower switch in cab.
 Have saw seat mogul go bad. Have also saw header control mogul cause header not to lower.         MACK
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:59am
since it raised, swap the raise and lower wires on the coil and pull of the master valve wire , then hit it raise button - if it lowers you have a electrical issue, if not you have hydraulic or mechanical issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 4:45pm
Well thanks for the help guys, the problem was the oil pressure safety switch wires run underneath the oil pan and had been chewed in half! Butt connected it back and all is well.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:17pm
Wow, I would've never thought that. This just solidifies I can fix the mechanicals on these combines, but when you mention electronics, I get totally lost.
