D17 S1 split at torque housing (Clutch shaft bear
ACthunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACthunder Quote  Post ReplyReply Direct Link To This Post Topic: D17 S1 split at torque housing (Clutch shaft bear
    Posted: 06 Apr 2017 at 11:22pm
D17 S1 split at torque housing (Clutch shaft bearings)
When we split the tractor I noticed that these bearings don't seem be all there. I didn't see any drop out... this is the engine clutch shaft correct? looks like I need to order #41 and #42?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 7:08am
Yes, those are the parts that you need for the clutch shaft. Be sure to also replace the seal on the transmission input shaft behind the power director assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 7:29am
I think you should COMBINE these threads into ONE.  You'll have to copy and paste from the other two into the one you want to have, or start a new one and copy and paste into that one.
This will keep it all in one place and help ALL of us who are doing the same thing down the line.
GREAT job so far!!  You're doing your homework and checking into it.  Keep it up!!
