ACG transmission fluid fill
roundrightfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roundrightfarm Quote  Post ReplyReply Direct Link To This Post Topic: ACG transmission fluid fill
    Posted: 06 Apr 2017 at 10:26am
Greetings,
I'm repairing some shifter linkages and I have my model G split right in front of the transmission, between the main gear housing and the small frame piece that holds the operators seat.  There are two separate compartments that contain transmission gears.  The forward compartment has a drain plug, but I can not figure out where to add transmission oil.  I can not see how oil putting oil in the only fill port adds oil to the forward compartment.  Am i missing something, or are there special fill procedures for this small forward compartment?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 10:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote roundrightfarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 10:51am
Thanks so much, its great to have a manual!
The manual does not mention anything other than to use the main fill port.  Still, the front compartment does not appear to have any connection to the main section.  Perhaps as the gears pick up oil, some will get transferred forward along the shaft.  Or perhaps I am just missing an obvious detail.  I will have to leave the front drain plug off as I refill to see if any comes out.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 1:45pm
It will fill no problem, just fill at the main plug by the pedal, then give a while for the oil to flow and level out.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 5:30pm
Manual says transmission/differential has 3 drain plugs and 1fill plug. Capacity 8 quarts.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 6:53pm
The transmission in the G is the same as in the B & C.
Dusty
This page was generated in 0.081 seconds.
