Difference between starters
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Topic: Difference between starters
    Posted: 05 Apr 2017 at 9:15am
Looking for a starter for a 7020. Sick of the Lucas.Would really like to go with a Denso reduction starter. Does anybody know what the Lucas was/is rated at in hp or KW. The Denso I can find is 79003057N through AGCO, which I believe is 2.5KW. There is also a 4.0KW starter listed for the 670T engine. Will a starter from a 426 fit a 301, or is there just no way this will work? Thank You
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 10:03am
426 starter won't work. The little 2.5kw denso will spin the piss out of the 301. Makes them start easier!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
