generator or alternator on a d14
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: generator or alternator on a d14
    Posted: 04 Apr 2017 at 4:40pm
it appears the 12v generator in my d14 isn't charging. so is it a good time to switch to an alternator or just have the generator rebuilt?  I checked the generator with a multi meter and I'm lucky to get 3 volts out of it when the tractor is revving and even that isn't consistent.  couldn't tell ya the rpms since my tach don't work. neither does the voltage gauge.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 4:51pm
I like to keep everything original and so I get the generator rebuilt. The big issue is that if you rebuild the generator it will be $200.00 unless you do it yourself. An alternator will be $70-$100.
 I've only had to have 1 generator rebuilt 18 years ago and it's still going strong. Old tech is still good.
Thanks & God Bless
Dennis
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:04pm
Are you sure it is a 12 volt generator.I believe all d.14 were 6 volt from the factory.
Gary
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:09pm
There are a couple suspects when a generator isn't charging. One is the generator itself, could be shorted turns in the field coils, or the armature, or worn out brushes, or a damaged commutator. Then there is the voltage regulator that controls the charging voltage. Check for voltage on the field terminal of the generator (or the regulator if that wire isn't connected the generator won't put out). If there is a few volts try grounding that post to see if the generator output voltage goes up. The generator output voltage with the field post grounded depends on the generator speed. If the generator puts out more than 14 volts its a sign the regulator isn't connected properly or is bad.
Another place to check is the generator belt and pulleys. The V pulley on my gas 4020 was so worn the sides of the pulley groove were parallel and didn't get pulled much by the V belt.
An alternator with an internal solid state regulator is an order of magnitude better at charging without over charging the battery. It sure isn't original but it works better and way longer.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:11pm
I asked the fella I bought it from and he said it was 12v, when 12v battery didn't charge when running I doubted it.  but the tag on the generator says delco 12 volt.  the positive wire goes to the points, so I'm guessing it's supposed to be 12 v negative ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:13pm
58ish... they went to 12V system. easy way to tell, check the starter. IF it has a steel band on it(brush cover) it is SIX volt.....
I converted all 4 of my D-14s to alternators ( CS-130 series ) as some were 6V,some 12V , 1 old delco alt, 1 ford alt. Now they're all the same.
Some reasons to change are...1) 12 volt is standard these days 2) faster recharge of battery 3) able to add more lights, winches, etc.
 Now you should replace all the 50 year old wiring while you're at it!!! Get a hold of Steve@B&B for a kit.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:59pm
serial# dates this d14 at 1960, no band on the starter, a tag on the starter  says 12volts.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 8:21pm
Gary
My 58 D14 is 6 volt.  My 59 D14 (over serial #19001) is 12 volt.  Both tractors are original with generators.  To answer the original question, just get the generator rebuilt and have it tested with the voltage regulator to make sure they get along.  Putting an alternator on means cutting up the wiring harness and I hate seeing that!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 8:43pm
You can get a 1 wire Delco alternator off ebay for less than $60,I just put one on my Oliver
1600 Utility.Saved all the original stuff.Run the wire from the alternator to where the battery cable hooks on the starter solenoid and you're in business.If generators+voltage
regulators were better they'd of never started using alternators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 6:18am
was in the middle of testing when it began to snowAngryAngry miserable pa weather.  I will do more testing this morning with hopes of it being some thing simple.
50's today and tomorrow, low 40's and rain snow for Friday and Saturday.  Sunday  60's Monday Tuesday in the 70's.....just gotta love pa weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 8:14am
tried grounding the field terminal and got no change in the few volts it was putting out.pulley was a little loose so I tightened the belt, still no change, just a few volts and some times it is negative volts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 8:32am
I like the 12 v alternator conversion. They work very well and are bullet proof after doing the new wiring correct to! I have done three WD's and am very happy with them.
The choice is yours. Sometimes it depends what you want to do with the tractor?
I do still have a 6 volt system (generator) on the Ford Jubilee and it preforms well. But when really cold, you keep your fingers crossed if you need to start it. Central PA, I would consider the alternator upgrade. And its 12 volt all ready. You can get the real small alternators now too.
I just put a small alternator on the1952 IH dozer when  the generator went south. More pricey but I liked the fit.
On a D14 this might be the ticket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:44am
Actually, its totally up to the individual what he or she wants to do. You can have the Gennie rebuilt and a new VR mated to it, which obviously, if done correctly will be twice as much as upgrading to an Alternator. Gary's line is funny, but he's correct in his statement. I don't suggest one wire Alternator's for Tractors, but again, to each his own. The 3 wire version works great for Tractors because most older earlier Tractor engines aren't designed for high rpms. Most one wire Alternator internal VR's excite at 1200-1400 rpm. There are a couple out there that respond now to a little lower rpm for excitement, but there's nothing like firing up the Tractor, bringing the rpm's up to around 450 (where its easy on the engine) and the Alt is charging without reving the piss outta' the engine. A lot easier on parts to. We offer a retrofit kit for the "D" series Tractors to replace the Gennie or older "DN" series external regulated Alternators if interested. If the wiring on the Tractor has been replaced before and is in real good shape, it should work fine for you. As  Jay mentioned, we offer complete 12V conversion wiring kits also if interested. Visit our website. There's lottsa' good information on 12V systems I put on the site from the 49 years I've been doin' this stuff....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:59am
The auto electric shop that supplied the 10-SI that I put on my gas 4020 had a bracket that adapted its mount to the generator mount, but I had to drill new holes in the bracket. They ordered a wide and small diameter pulley that solved two problems. It turns the alternator faster than the original generator pulley would have and it allows the fatter alternator to use the original fan belt. With a 2-1/2" alternator pulley and a 5 or 7" crankshaft pulley it takes about 1650 engine RPM to start the charging.The working speed range under load for that engine is about 1100 to 2250 RPM, no load idle about 850 RPM IIRC. Once the alternator gets started it charges down to the slow idle speed, so it doesn't require continuously running the engine fast. Though with a cold engine ideally it would be nice to not even goose it up to 1650 until it is warmed up. The three wire connection would solve that I'm sure.
The alternator has significantly increased battery life by charging faster but not overcharging.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 10:13am
The ones I've been getting off ebay have a double pulley makes it a lot easier to get the belt to line up on different tractors.Also it starts charging as soon as the tractor fires up
at regular RPMs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:46am
well it looks like the genny is toast, I tried every thing I could find on the net to test it and nothing changed.  as this is going to be a work tractor the less things to go wrong the better, so i'm gonna get an alternator, a friend of mine has a few chevy alternators laying around. I'll stop at the auto parts store and have it tested.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 3:03pm
Got 57 D 14 6 volt and it quit . Took gen apart and wire going to brush went around screw wrong and when brush wore spring could not push it down on commuator.Had never been apart. Work good now no cost just a ittle time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 3:59pm
Often the brush push down spring gets hung up on the brush holder when the brush gets short and then the brush doesn't make good contact with the commutator.
But there are as many things that can go wrong with a generator as there are turns of wire in the armature and field windings. And sometimes all those can go bad if the bearings wore enough to let the armature drag (and heat) on a pole piece.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 7:17pm
If you use your tractor for short runs, an alternator is better. generators are great for 'all day' use, as they slowly recharge the battery but for 10 minutes here, 15 there, kinda days...an alternator will keep the battery properly charged.
Also better if you add a winch..
BTW you should carefully look at all the wiring....after 50-60 years, it'd be a good idea to replace it. ANY corosion( blackend copper, bluish-green..) do your tractor and you a BIG favour, get new wires for her !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 7:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 8:51pm
Since the alternator can generally put out 2wo or 3 times the current of the generator, the main output wire going to the battery through the alternator needs to be larger as does the ammeter. Rated for 60 amps instead of 20 or 30 amps. Like 6 gauge.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 3:35am
wow, nice looking machine. no fear of my d 14 looking that nice for a long time.  This will be the main work horse now.  With the lack of parts available for the 5020 I wanted something to take most of the stress off it.  it will still need to do the tilling as the d is still to fast even in low to till.  so far the wires all look good, no cracking, discoloration not even all hacked up.  heck there is a braided copper ground wire that is still copper color.  I'll know a bit more when I start taking things apart.  good tip on the volt meter and wires thanks. dt
Edited by dt1050 - 06 Apr 2017 at 3:46am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 5:59am
Automotive wiring is rated differently from NEC household wiring. For 60 AMPS my automotive chart shows either 10 or 12 AWG, depending on the length. Remember that alternators are rated in peak AMPS. A 60 AMP alternator would be expected to put out 30 AMPS continuous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 11:05am
Doug you have it backwards. The NEC rating is based on temperature rise of the conductor limited by the softening point of the insulation. At low voltage the voltage drop is more of a limiting factor than wire heating. NEC allows 3% voltage drop typically, that's 3.6 volts for a 120 volt circuit, 3.6 volts on a 12 volt circuit is 30% and cuts the power at the load seriously. Like down to half the power to the load. And the low voltage current still heats the wire so the low voltage wire needs to be at least as large as NEC for wire heating and larger to keep the voltage drop under control.
The alternators I've read ratings on are OK for hours at the maximum rating.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 11:16am
I've worked on vehicles with 100+ AMP alternators and I've never seen alternator wire heavier than #8. Look at your own car. The NEC isn't concerned one bit about the wiring in a motor vehicle. The NEC code is designed for structures safety. Wire insulation in the open air with the proper insulation will not melt nearly as readily as with multiple conductors in a conduit. If you want to be a purist, go ahead and run #6. I'm just saying that you won't find that thick of wiring on any 60 AMP alternator on a car or tractor. BTW, if you look at your battery spec sheet you'll find that a battery shouldn't be charged at greater that 20 percent of its reserve capacity. If you have a battery with a RC of 100, which is getting into big battery territory, you really shouldn't be pouring more than 20 AMPS into it.
Edited by DougS - 06 Apr 2017 at 11:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 1:04pm
Most of your heavy truck applications equipped with 130,140, to 150 amp rated Leece Neville or Delco Alternators usually run #8 for the output lead. Any Automotive application from 35-120 amp rated Alternators, #10 is fine in the engine compartment and feeding into the cabin. If the Battery is located in the trunk like in race cars or hotrods, #8 or #6 for a power-in line would work better because of distance and keeping voltage drop in mind. 1 gauge Battery cable (or larger if your prefer) works well to the Starter motor and for a grounding cable. What I usually do on those applications is run both the hot and the ground up to the Starter motor. The ground cable I connect to one of the Starter motor mounting bolts, then swing a grounding strap over to the frame rail and firewall to insure good grounding loop.
Steve@B&B
