White tractor hydraulics
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: White tractor hydraulics
    Posted: 03 Apr 2017 at 9:08pm
So I took my white 2-70 up to the old place to raise my new digger that's all folded out. I hooked up all the lines everything was ready. I made sure the hoses were hooked right. I pulled the first hydraulic and the center went up. Perfect I thought. I pulled the next hydraulic and the wing rams started going in untill they got a little wieght on them and then everything stopped. Grr not so perfect. Let everything down check hoses and they were right. Swap hoses from side to side and now wings go up but when I go lift the center same thing. Get a little wieght and everything stops. I tried both tries with the rpms up to about 900. Even though I won't be using this tractor to dig it would be nice to know why one hydraulic will lift and not the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 9:14pm
Coupler or hose ends are bad.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 9:25pm
Coupler on the tractor?
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:17pm
This is off topic, but how do I start a new post?  Can't find a place to click to start.  Thanks.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:24pm
For smiling John..look in the top left corner, there's s box that has "new topic" oh yea, its on the main topic page, under the heading of whatever page your on...ie Farm Equipment
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:35pm
prolly have air in the lines, and like Mack says, check couplers
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:44pm
My 1800 oliver needed to be running about 1800 rpm to lift most heavy stuff, even with the new pump.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 11:21pm
Are you using the tractor controls directly to control it or are you going thru another valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 11:42pm
I'm going just off the controlls in the cab. I've added nothing new or exotic. I don't think it's the hydric pump that's bad because it will lift either operation from the one side. But like I say that one side just seems to give up when it gets a little wieght on the cylinder.
I'll do as Mack suggests and put new couples on the one side. I can't believe it could be that simply. I feel silly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 4:54am
Hopefully its the coupler but I suspect you're going to find its something like a blown
O Ring in the valve.On one of my Oliver 1550 tractors the remote is weak on the left side.
Rather than tear into the hydraulic unit you could always add remotes thru the Power Beyond and then you have extra remotes for other things.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 7:20am
So the trouble follows the tractor control, not the hoses, since you swap them and the other section lifts.
Is there an adjustment on the tractor flow per remote?
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:44am
Is the first valve returning to center? Check linkage on the levers? Maybe one locked in detent? Good luck, Scott
