Need a Recommendation
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Topic: Need a Recommendation
    Posted: 03 Apr 2017 at 1:49pm
What do you guys use for V-belts? I need a new one for my B... My experience with the TSC ones didn't impress me much, they seemed to die FAST, really fast.
So I am wondering what you guys use?
Thanks,
Ben
'39 Model B
Tractors are cheaper than girls, remember that!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 4:40pm
I've always got mine from Napa and never had a bad one.  They seem to last a long time.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 4:57pm
I get them at O'reilly. It's about the only place around that has somebody that knows how to measure belts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 5:40pm
Is everything properly lined up ? even a 1/16 out of whack will force a good belt to wear out real fast.
pulleys running 'true'? no weeble-wobble  allowed !!
kevlar reinforced belts are much better than 'dime store' V belts...
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 6:16pm
If I know the measurement, I use Surpluscenter.com.  A $40(dealer) B-88 like my Dixie Chopper uses is $10 at SC.com.  No matter what belt I put on it, dealer, or cheap, it eats up about 4 a season, sometimes less...  SC.com also knows how to ship, I buy belts, when I order something else, they use the belts, as packing, in the same box...
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:50pm
Napa, been getting them there since 1973.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:06am
Looks like I will try a NAPA belt.....  Thanks guys!
@ jaybmiller - There isn't any very noticeable wobble, but good point... I will look at it very closely and see what I find out. Big smile
'39 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:07am
Well..... that might work, except that there aren't any O'Reilly stores 'round here! Thanks though!!!
'39 Model B
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:09am
I have used both NAPA and belts from O'Reilly's. Prefer the NAPA also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:56am
I use Gates. I've had a Gates green stripe on my B for at least 10 years now. Napa's belts are made by Gates, so you shouldn't have any problems unless you have a pulley misaligned or another issue going on..  HTH
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:21am
I get my belts from the JD dealer they stock mostly gates belts except for the JD belts for the garden tractors. For my simplicity I go to the simplicity dealer. There belts are based on 1/2" measurements so a standard 1" sized belt won't work for long.
