spray Metal
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Topic: spray Metal
    Posted: 02 Apr 2017 at 1:23pm
Have any of the restorers on here used a spray metal process to fix rusted out fenders,  body parts, rims or sheet metal?  I have heard of this process for building up shafts.  There are some neat youtube videos. The equipment for this looks expensive.
The universal answer to all questions is yes, how much do you want to spend?
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 5:08pm
Epoxy is way cheaper. Spray welding fumes are not fun to breathe either. Unless you need to heat shrink a bearing on a shaft, products like Belzona 1111 supermetal are cheaper to use and have excellent strength.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:01pm
Before applying ANY epoxy,  proper surface prep is necessary.
Grit blast the surface to a near white 3 mil finish , utilizing a coarse angular abrasive such as black beauty.
Belzona 1111 is an awesome product.  Easy to use Far superior to JB Weld or Devcon.
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:12pm
This is off topic, but how do I do a new post?  Can't find a place to click to start.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:46am
When you look at the "Farm Equipment" page, off to the left, toward the top of the topics, you'll see a button
[ New Topic + ]
Just click on it and have fun!!
Edited by Ted J - 04 Apr 2017 at 9:48am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 10:31am
You joined in 2009 and don't know how to start a thread?
Seriously, is this logon hacked?
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 7:34pm
I know a couple guys that use spray welders mostly to repair old non-replacable manifolds on rare tractors. Takes some practice, not cheap and most of all, like stated earlier, fumes are dangerous.
This page was generated in 0.035 seconds.
