210 fueling adjust
navyrunfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote navyrunfarm Quote  Post ReplyReply Direct Link To This Post Topic: 210 fueling adjust
    Posted: 30 Mar 2017 at 10:03pm
hey all. wanting to turn fuel up just a little on my 210 for chisel plowing. need advice on how to do it. thanks!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 3:11pm
turn out the torque screw - it is the screw under the plastic cap sticking out at a 45 degree angle pointing back toward the steering wheel on the same plane as the throttle shaft but on the rear of the top of the pump-it is the only screw not parallel or perpendicular to the plane of the pump area.   Remove seal, warranty is out, loosen jam nut , insert allen screw, and turn out couple of turns, tighten jam nut - do not over tighten.  If it has already been done - likely - it is like if you have to ask, don't do it - have a pro do it .. a seized pump head is a terrible thing to waste...
This page was generated in 0.060 seconds.
