185 Hydraulic PTO Clutch Option
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Topic: 185 Hydraulic PTO Clutch Option
    Posted: 26 Mar 2017 at 2:56pm
My 185 does not have the hydraulic PTO clutch.  While at a salvage yard recently, I found that every 185 in the yard had a hydraulic PTO clutch.  Is it possible to "bolt on" the control valve, lever, linkages, lines, and PTO clutch housing underneath the tractor?
Might not be worth the expense, but wondered if any of you guys have done this.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 3:21pm
Also need to change rear lift housing along with gear in torque tube housing.    MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 7:08pm
You only need the lift housing if you are changing for single speed to 2 speed PTO or vise versa. Otherwise all you need are the items you stated. The clutch has to match the PTO speed you have.
