D14 steering wheel removal
HVFDFIREFIGHTER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Topic: D14 steering wheel removal
    Posted: 25 Mar 2017 at 2:49pm
After much encouragement and muscle, I was able to remove the nut on the steering wheel. The steering wheel will not budge. Is there a trick to removing it? I want to take it off and replace it. It is badly cracked. I'm a little hesitant to heat it as rubber is all around and gas tank is not far away. Any help is always appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 2:52pm
Is there a roll pin that needs to be removed?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:47pm
no roll pin if your's  has a nut retaining it.
you can use a puller and a little bit of heat.
or use the puller and a air hammer from the bottom of the wheel to knock it loose.
obviously your not worried about any damage to the steering wheel if your replacing it.
wrose comes to wrose you can cut the plastic off to get to the metal core to put your heat on and puller on.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:49pm
The parts explosion does not show a roll pin, but does show a snap ring.
Go here:
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
Beside Guest user click View Books.  Under Search by Model, enter D14.  Where it says All Brands, pull down AGCO Allis.  Click Search.  Click on D14 Tractor.
Scroll down to Axle ... Steering Shaft & Support
Blow up the parts diagram and have a look.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:40pm
I had to cut the hub on my d17 steering wheel to get it to come off. Make a cut with a grinder with a cutoff wheel inline with the steering shaft but don't go all the way thru because you can damage the splines underneath. Then use a chisel to split the hub open and it will come right off.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:57pm
Go here:
The snap ring is under the steering wheel and does not need to be removed to get the steering wheel off.  For all of mine, I use heat, penetrating oil, a gear puller and plenty of cursing.
