190 XT Injection Pump
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT Injection Pump
    Posted: 24 Mar 2017 at 7:30pm
Does the 190 have a screen or filter where the fuel line goes into the pump? Changed the
spin on fuel filter and its running good for a little bit but then starts to stave for fuel.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 8:21pm
The two sediment bowls, located under each corner of the fuel tank, should have a screen in it. You would want to start there to ensure ample fuel flow and move forward from there. If you have steady fuel flow to the injection pump and is still starving then probably injection pump issue. Do the easy troubleshooting first. Good luck, Mike
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 8:36pm
There should be a check valve on the top of the pump (return line) that gets stuck or plugged that could be causing those symptoms also.
WD,D15,190XT,7000,8010x2,7060,8070
