Gleaner L header on an L3?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L header on an L3?
    Posted: 17 Mar 2017 at 11:29pm
Will a header for a L fit right on an L3? My uncles are going to be needing a pickup for their Canola this year, and I found a 13' header with a pickup that came off an L for $1,000. Seems cheap enough, but I was wondering if it would fit.
The same guy also has a 1980 L2 with a 24' header he is selling for $7K, so I'm thinking he must have used this other header and pickup on it as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 7:41am
I don't know of any reason it would not work.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 8:30am
Ok thanks...I just thought since they made so many improvements over the L's to get to the L3's, they might have changed the feeder house mounting brackets some.
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 2:49pm
It will hook up just fine
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 11:29pm
you will have to trim some on the vertical member on the RH side to make clearance for the feeder beater drive sprocket and hub.
Or find a wrecked 77+ L/M header and swap crossmembers.
If the guy had been running it on a L2 allready, I bet any and all necessary trimming is allready done.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
