8000 series tach Issue |
pdh
Topic: 8000 series tach IssuePosted: 17 Mar 2017 at 6:32pm |
Went to look at an 8050 today. Tach does not work at idle. Throttle to wide open and it starts working and seems "normal" as long as throttle is wide open. Back off the throttle more than 100 or 200 rpms and it quits reading again. Fixable? Or have to replace?
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 17 Mar 2017 at 6:53pm |
The sensor pickup needs to be adjusted. It's very easy to adjust. Just unplug it and screw it in until it touches the flywheel then back it off one turn and plug it back in.
Thanks & God Bless
Dennis |
pdh
Posted: 18 Mar 2017 at 5:31am |
Sounds easy enough - point me to the general location of the sensor? Thanks.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2438 |
Posted: 18 Mar 2017 at 8:02am |
Left side. Below the starter.
pdh
Posted: 18 Mar 2017 at 10:41am |
Many thanks to both of you.
AllisandGleaner
Posted: 21 Mar 2017 at 7:23pm |
Ok I have the same problem with my 8030 and I tried to adjust it as said and it still has the same problem, doing the same thing. Like it tries at idle but not enough you have to rev it up to 900 rams to get a response. Any pointers?
Unit3
Posted: 21 Mar 2017 at 9:40pm |
Trouble with an 8000 series tach, join the club. Oh the joys of an old tractor.
Ron(AB)
Posted: 21 Mar 2017 at 11:28pm |
Do you have another used tach to swap out and compare/trobleshoot? |
AllisandGleaner
Posted: 22 Mar 2017 at 6:14am |
Nope it's my first 8000 series tractor so this is new territory for me.
DennisA (IL)
Posted: 22 Mar 2017 at 4:31pm |
The next step is to check the ohms of the pickup. I don't know what the ohms should be. Be best to compare to a new one if you can. Pickups can and do go bad.
Thanks & God Bless
Dennis |
