7010 AC Part ID??
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 AC Part ID??
    Posted: 16 Mar 2017 at 4:13am
Below are photos of a ?fuse? that is clipped to the block just in front of the coolant filter on my 7010.   I must have bumped it when replacing the filter recently.
What is this?  The wire runs up to the air conditioning compressor.
What do I look for when trying to find a new one?
Thanks,
Roscoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 4:16am
Second photo:
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 7:16am
It's a GM air conditioning fuse or sometimes called a thermal limiter. Any automotive parts store should have that.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 7:17am
i think that's whats left of the thermal limiter fuse for the air conditioning system!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 7:18am
Just ask for a GM air conditioner fuse or take it off and bypass it.    MACK
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 7:39am
I agree with the bypassing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 8:57am
So just stick a jumper wire in the two outside slots?
Thanks!
What is a thermal limiter supposed to do, anyway?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 11:16am
Stolen from the internet, cause I am too lazy to type.......
A thermal limiter is much like a fuse. This device was used on many General Motors cars and trucks during the mid to late 1970s and was designed to help protect the compressor inside the air conditioner. The thermal limiter switch keeps the clutch in the air conditioner from engaging when the air conditioning system is low in refrigerant. The superheat switch sends the information to the thermal limiter switch to prevent the clutch from engaging. When refrigerant levels in the air conditioning system are too low, the evaporator within the system will be forced into superheat conditions. This simply means that the vapor from the refrigerant in the system’s evaporator will become overheated. When the superheat switch, which is located in the rear head of the air conditioner’s compressor, gets the signal that the evaporator is being overheated, it will send the message to the thermal limiter switch which will in turn completely shut down the air conditioning system within the vehicle. This is done to prevent damage or failure of the system.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 11:19am
After reading that, I think I'll spend the $6 for a NOS Made in USA switch.
Thanks!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 8:38pm
a words of caution - if the coil on the compressor clutch is drawing too many amps it will blow the fuse,,, by passing it will eventually melt the harness..// check the amp draw on the coil - should not be over 5-6 amps.   country boy way to check is take a 12v powered wire and touch it to the coil wire with a 5 amp fuse in-between  - should not blow fuse.
