AC pumpkin planter! |
KY
Topic: AC pumpkin planter!Posted: 13 Mar 2017 at 8:12pm |
Have any of y'all ever tried to plant pumpkins with a plate type AC corn planter??? If so which plate did ya use? Soybean plate? Thanks
DougS
Posted: 13 Mar 2017 at 8:26pm |
Even with the plates slowed down as far as you can, wouldn't the plant density be too high?
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 13 Mar 2017 at 8:30pm |
You could fill in the extra openings to every other one or every third one or even fourth. Then pull it across some pavement and measure the drop rate.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3659 |
Posted: 13 Mar 2017 at 8:48pm |
call Lincoln Ag Products sales@lincolnagproducts.com
They have the plates and adaptors if you don't have them.
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 328 |
Posted: 13 Mar 2017 at 10:07pm |
JD has a pumpkin plate that will work, still available threw parts. But yes you can take a corn plate and fill all the cells but 2 or 3 spaced out. Then grind the cells a little longer to fit a pumpkin seed. Andy
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 13 Mar 2017 at 11:13pm |
I used to use a jd planter for pumpkins before I got my vacuum planter. I got some steel blanks either from the jd dealer or Lincoln, don't remember now. Ground out slots for different size seeds on different plates. Changing the sprockets got it turning slow enough to plant on 30" - 36" spacing.
Allis Express participant |
Mikez
Posted: 13 Mar 2017 at 11:33pm |
I always wanted to try to set up planer for pumpkins.
We are just using our old new idea transplanter and dropping seed into the opening, works good |
KY
Posted: 14 Mar 2017 at 6:57pm |
Ok thanks for the info!!! I'll let y'all know how it goes!!
KY
Posted: 14 Mar 2017 at 6:59pm |
Yes that's what I'm afraid of. Even with a 20 cell bean plate and as slow as it will plant it is pretty heavy!
Stan R
Posted: 14 Mar 2017 at 7:39pm |
How many acres are you planning on planting?
