Hastings LF405 - June 4 Update |
Post Reply ![]() |
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Mar 2017 at 5:02am |
Good morning! I've read good things on here about using these oil filters on tractors like the WD45, so I installed one when I changed fluids in mine. I'm getting a pretty low (about the "N" in Normal) oil pressure reading. With the old filter, likely a Fram 159, it read more mid-range. I bought the Hastings filter last fall and have another from the same purchase installed on another tractor which seems ok. Have there been any consistency issues with the Hastings filters lately? Thanks! Dave
Edited by Dave(inMA) - 04 Jun 2017 at 9:34pm |
WC, CA, D14, WD45
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Did it look like it was stuffed with cotton? When you pulled the stick out did it feel like it was embedded in cotton? If not I'd be concerned. I will say that it appears you have plenty of oil pressure, regardless of previous readings.
Thanks, Doug. It LOOKS like it oughta be okay - slightly concave on the business end and what appears to be cotton inside, looking through the hole for the tube.
I'm not too worried about it given what I've read on here - but it seems odd that it'd have less pressure with fresh oil right up to the Full mark....
WC, CA, D14, WD45
JarrodACFan ![]() Orange Level ![]() ![]() Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
That's what I use on my WD45, except the Baldwin version (same thing, different name). When I changed the oil last summer, the new filter was filled with cotton like previously stated. I think you ought to be fine.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
So with the right type of filter, anywhere in "Normal" is okay?
Thanks Dave
WC, CA, D14, WD45
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Normal is normal, ideally yes you would be between the R and M but you're fine. New, clean filter = less resistance and less pressure until it gets fully saturated and a little dirty. Your cam bearings might be a little tired.
Thanks, Bill. Nice to bring a little experience to bear on these topics!
WC, CA, D14, WD45
An update to my original post. After running the WD45 about an hour, the oil pressure gauge is now reading below the N. I was expecting the reading to rise a bit (based on previous posts) after some use......not the opposite. Maybe oil isn't getting through this filter and back to the engine? I'm thinking maybe I should change out that filter.....any opinions? Thanks!
Dave
WC, CA, D14, WD45
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Being a bypass filter, if the oil is getting through the filter too well it causes low oil pressure.
Some years ago all the filter makers went to a paper filter and destroyed a bunch of AC tractor engines because the oil flowed too easily. The oil gets to the filter when the pressure regulator (ball and spring) valve opens. If the filter doesn't have enough restriction the oil pressure drops more than desired when passing through the oil pressure regulator valve. Gerald J. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87553 |
the filter causes BACKPRESSURE and only bleeds off 15% of the total oil. AS the filter gets OLDER it may restrict more and cause the pressure to go UP slightly. If you have a new filter ( packed cloth type) and the pressure is not above the N mark ( just like you FRAM), then you probably have some wear in the pump itself. You could put a real gauge on and see the actual pressure, but your probably OK right now. Most tractors lost a couple psi over the last 50 years..... In hot summer, you can changed to a thicker oil like 10w 40 if you want a pound or two more psi.
Thanks for the replies. I'm a little confused, though. Here's how I'm reading them: Gerald's suggests that the low reading means not enough back pressure and that might destroy the engine. Steve's suggests that I'm probably ok but maybe want to switch to 10W-40 (vs the 10W-30 I'm using). Can someone untangle this for me? Thanks!!
Dave
WC, CA, D14, WD45
20W40 or 30W should bring up the oil pressure some. I'm of the opinion that none detergent 30W is abusive to the engine causing more rapid wear and filling with sludge because of lack of anti corrosion additives. 10W30 vs 10W40 may show a difference in pressure the effect will depend on the oil temperature a great deal.
Gerald J. |
I wanted to report back after trying a couple fixes. First I switched to a Fram C159. Pressure still read low. I then removed the center tube and inspected it - it was open but corroded - mostly on the exterior. Replaced it and now pressure reads in the Normal range. Could be that the corrosion was impeding oil flow.....
Thanks again to everyone who offered suggestions.
WC, CA, D14, WD45
The opposite would be true if the tube were plugged. Perhaps the tube was leaking at the bottom and it sealed when you replaced it.
That's possible, Doug. It's one of those minor mysteries of life, I guess! :)
WC, CA, D14, WD45
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
Is a Baldwin JC405 the same as Hastings LF405?
Dave, your still looking at this like an automotive filter... YOU THINK you want to pass a lot of oil thru the filter and keep the pressure high going to your bearings.............. This motor does NOT work that way... Lets say your pump puts out 100% of a given flow... The "TUBE" in the filter has a pin hole in it and allows 15% of the oil to be filtered and DUMP BACK TO SUMP... YOu only get 85% of the oil going to the bearings for lube.. If you REDUCE the size of the hole in the tube, you might leak 10% of the total oil back to sump, meaning you would put 90% of the oil to the BEARINGS........... In THEORY the highest flow and pressure to the bearings is obtained when the filter is PLUGGED or the hole in the center tube is RESTRICTED..
Edited by steve(ill) - 13 Jul 2017 at 4:54pm |
monkey - I think a jc405 is a sock filter that slides INSIDE a can... Not the same as LF405. Look for a photo of the JC405.
Wow! Thanks, Steve. You're certainly right about how I've been thinking about this. But given your explanation, isn't there a trade-off between the oil quantity getting to the bearings and how much gets cleaned by the filter in a given time? If 85% to the bearings becomes 90%, that's a 6% increase in that flow.....but the flow through the filter would drop from 15% to 10% which is a 33% reduction. I'm not sure I'm thinking about this properly, but if I am, wouldn't I want to avoid cutting the filtering action by 1/3 if the flow to the bearings only increases by 6%? I guess it'd depend on whether 85% is "enough", right?
Thanks much, Dave
WC, CA, D14, WD45
I have 8 new sock JC405s for sale, I was hoping they were the same as the LF. Thanks |
Post Reply ![]() |
