PTO Drive Shaft
boilerpete View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerpete Quote  Post ReplyReply Direct Link To This Post Topic: PTO Drive Shaft
    Posted: 08 Mar 2017 at 7:54pm
I've got a PTO shaft with the yoke that has the collar that slides forward to lock onto the PTO shaft.  There are 4 ball bearings in the yoke that are supposed to release when the collar slides and then lock onto the detente on the PTO shaft after the collar is released.  It worked just fine when I parked the spreader last fall, but I can't get the ball bearings to release and lock onto the PTO this spring.  They rotate with my finger, so they're loose, but they won't release.  I've soaked in in PB blaster, don't think there's any crud in the collar, could be wrong on that though.
Ideas?  Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 8:36pm
Assuming there is no physical obstruction, causing the shaft not to slide all the way forward, have you tried to rotate the shaft's position on the pto shaft?(try shifting the imp shaft a couple splines over)  sometimes wear can cause the situation you describe...
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 8:46pm
I've had to stick the locking end in a bucket with diesel fuel or kerosene and let it soak a day before. Sounds like you might have a bit of rust or grit up under the collar not letting it spring forward enough to push the balls down
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 8:47pm
Collar may not be moving far enough to let balls drop out far enough.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:03pm
Have one on a post hole auger that was left on the place when I bought it. Does the same if not protected when not in use and also lubed well.
Likely have grit in the assy. and it does not take much to keep the collar from coming forward over the balls.
Second the soaking it in diesel comment mentioned, and keep working it by rotating it while in diesel.
