Affordable GPS project
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Affordable GPS project
    Posted: 06 Mar 2017 at 8:51am
A little update on the affordable GPS project.  I figured I would start a new topic so it would be a little easier to follow.  I came across a free Windows-based application that some guys in Canada have been working on together that seems like it might be worth trying.  You can download it here using the "clone or download" button.  https://github.com/farmerbriantee/AgOpenGPS
You just download the file, extract it on your computer, and the application is in the file (no need to run a setup or anything like that, it's a pretty basic program).  I played around with it briefly with my old GPS unit (severed wires taped back together to make it work for now) and it seems like a simple enough interface and it tracked my movements.  I haven't setup equipment in it, so I couldn't do any tracking or test the AB line, but if someone wants to give it a try, it seems like something that might be worth pursuing.  I believe they are working on or have in place some row-control features in the software.  If you type in a google search for AgOpenGPS, you will come across some forum topics on it and features and future features.
Still working on an affordable sub-meter GPS antenna.  There are actually guys making RTK systems with little mini computers called Raspberry Pi (Here is a link to one so you can have an idea what they are
I am trying to look into both setups, and I'm not sure the RTK system might not be similar in price to a sub-meter GPS chip at the end of the day (I think you can use less expensive chips with the RTK).  The RTK will take a good bit more time and effort to put together because you'd have to program the mini computer to use it with a free program that is out there.  Anyways, that's the update for now and I'll keep you posted as I get more done.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 9:20am
Hurst,
Thanks for the update! I will be following this for sure!
~Warren
Edited by Acfarm - 06 Mar 2017 at 12:45pm
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 12:00pm
Thanks!!!
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
This page was generated in 0.222 seconds.
