New tractor to me trying to identify
brelje85 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brelje85 Quote  Post ReplyReply Direct Link To This Post Topic: New tractor to me trying to identify
    Posted: 05 Mar 2017 at 12:25pm
Hello,  brand new to the forum
Bought a allis chalmers tractor, I don't know the size or year but have what i think is a ser. # 247876-03 A. The person I bought it from thought it to be an early 70's ? I tried to look up the numbers and have had no luck finding ser. #'s that new?  Its a four cyc. gas tractor, which ran for about an hour before the carb started leaking everywhere.
I am trying to identify the model so I can buy a new carb, the previous owner said he has had the old one rebuilt many times, and I want new and be done with it.
Thanks in advance for any help. I will post pics when I can figure that out.  Chris
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 12:34pm
can you get a pic ? or look on the left side bell housing at the ser no. the no. you posted doesn't look like a ser no.
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 12:40pm
Most likely a 170 or 175 could be a 190 you need to look at the bell housing where engine and torque tube come together should be stamped there on left side of tractor top of bell housing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote brelje85 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 1:21pm
I can't figure out the pic post ?? but I did find the numbers on the bell housing which is about the only area that I did not clean.... the numbers are 170 8078  so I am assuming its a 170 like you thought Craig. Would I dare guess the 80 78 is the 8th month of 1978?
Thanks for the help, this is my first real tractor to use for odd jobs around the property
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 1:40pm
no its the 7078 one built its a 1972 model serial # start at 1001
