WD45 Front Wheel Stud
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Front Wheel Stud
    Posted: 03 Mar 2017 at 11:43am
Would anyone know an automotive crossover for the front wheel studs on a WD45? I'm missing a couple, and the guys at the auto parts store are not very helpful when I tell 'em that they're from a 1955 AC WD45! The studs are 1/2" NF, 1" long with a relieved shoulder to tighten against the wheel.
Thanks!
Dave
WC, CA, D14, WD45
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 11:49am
stud
spec on bottom of page
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 12:35pm
Thanks, Stan. You got me in the right area!
For anyone else looking, those (ABC397) are for the rear wheels. The front wheel lug studs are smaller: ABC399 on Steiners' site.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 1:21pm
Ooops Thanks for the correction.
Doug-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 2:43pm
So are you needing some studs? I am sure local salvage yard has them, or I have some I could sell you? How many do you need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 3:37pm
Thanks, Doug. I appreciate the offer. I've found some, so all I'm set.
Stan - no worries - that's why we're a community on here. Smile
Dave
WC, CA, D14, WD45
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 4:08pm
3\4 head' fine thead' same as a VW bus or car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 7:34pm
Thanks, dawntreader74! Good to know.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:42pm
you can use some off a old running gear' if you can find one laying around somewear' there most all the same' with the same size head on it''Smile
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 2:53am
Are they metric? I wouldn't think so, but maybe they are. I'll wait until daylight and go see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 5:34am
Yup - I could borrow a couple from my D14 - it uses the same studs.
I ran a 1/2-20 thread chaser onto one of mine yesterday.....don't think they're metric.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 6:33am
Dave
Where did you find them Dave?
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 10:43am
an old dude that I bought my chevy allis from had scads of them bolts. so maybe that's why he had them. I puts them in my bolts cabinet, but haven't used any for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 6:37pm
Ted, the vendors on here carry them - at least Steiners does. I gotta believe that they were commonly used back when wheels were bolted on with studs rather than sliding them onto studs as we do now.
I ran all the studs through a thread chaser and ditto for the hub holes. Mounted the wheels with two new tri-rib tires. The 'ol machine is starting to feel spoiled!
Edited by Dave(inMA) - 05 Mar 2017 at 6:38pm
WC, CA, D14, WD45
This page was generated in 0.044 seconds.
