D17 Series 2 Rear Main/Pan Gaskets
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 2 Rear Main/Pan Gaskets
    Posted: 02 Mar 2017 at 7:38pm
Seems as though my D17 series 2 has sprung an oil leak. Leaves good sized puddles under the clutch area. Assuming rear main but haven't taken a hard look. How ugly of a job is this gonna be? Has a wide front and power steering. Service manual makes this sound a whole lot harder than my old WD was. Are the gaskets the same? Parts book shows the little F gaskets to be a different number as is the rear main. Aftermarket parts places list them all the same WD through D17. Any thoughts?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:12pm
Gasket sets come with both size F gaskets.
Pull motor out, turn up side down, and go to work.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 6:04am
Thanks Mack. The service manual makes it sound like I need to pull the front bolster and wide front axle as well as the radiator. Is it that much more of a job than a WD, or can the engine come out without the extra work. I know it'll need split unlike the WD, just hadn't planned on that much extra wrenching.
AaronSEIA
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 7:11am
It's not that bad of a job. Block between the axle and the bolster to keep from tipping and undo the frame rails from the torque tube and roll away. You then have clear access to the engine. Not harder than a WD, just different. If you have power steering the oil pan can't be removed with removing the front end so its easier to pull the engine than just pulling the pan and doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 1:37pm
If you haven't already, watch Don's video. Like Mack says pull the engine, turn it upside down and go to work.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:21pm
You might want to change the seal for the clutch input shaft in the torque tube while you are in there.
