Wc "styled" clutch change?
ruddyorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ruddyorange Quote  Post ReplyReply Direct Link To This Post Topic: Wc "styled" clutch change?
    Posted: 15 Feb 2017 at 3:41pm
Fella's  I am currently in the process of replacing the clutch on a 1941 Wc and i was wondering if anyone out there could tell me if I could use the 9 spring heavier duty clutch that i believe was on the later model wd45's? I was thinking this would be an improvement over the stock 6 spring that I removed. The only thing else I also wondered was if this can be done, would the pilot bearing also go in instead of the pilot "bushing" that it currently has?  I know that some of you guys have experience in this and would very much appreciate any help you could offer. Thanks so much, sincerely Hoss
3WD45's,1WD,2WC's(1unstyled)2C's,2B's & 2D17's& d15&CA sign on barn:EATIN FARMALLS an CRAPPIN DEERES,IF IT AINT ORANGE IT AINT IN HERE!
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 5:35pm
I have done it to my two WD tractors with modifications should bolt right up to your fly wheel
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 6:29pm
get with Rick Corder - rickinmo@socket.net
he's Mr Clutch around here
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 6:27pm
Did the same thing with my WD, the 9 spring setup came from Rick Corder, bolts up just fine. If you go through Rick he will make whatever kind of disc you want- fully lined, 4/6 button, spring, solid, etc. He also includes the correct pilot and throwout bearings. Be sure to get your flywheel face turned too.
Edited by Bill_MN - 16 Feb 2017 at 6:30pm
