8010 Planetary
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Topic: 8010 Planetary
    Posted: 03 Feb 2017 at 5:23pm
I am replacing the seals in the front planetary of my 8010. Does anybody know how tight to torque the big nut? TIA.
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 5:47pm
320 ftlbs
remember plunder than burn
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 6:30pm
Thanks a lot. Now I just have to make a socket to fit that goofy nut!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 6:39pm
You can still buy the tool i just ordered one the other day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 10:54pm
Bought a socket from OReillys-just had to massage it a little on the lathe to make it work. Should get it back together tomorrow, hopefully. Where did you order one from?
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 1:35pm
How about some specs-details or pics of the socket you guys bought & massaged for this job ? thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 5:50pm
The socket is from OTC 1931. I will try to get a picture next couple days. Does anyone know how the oil hole in the stationary shaft is supposed to be oriented? Up, down, or horizontal? TIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 10:16pm
i ordered my tool from my snap on guy. he is a dealer for kent moore. i wont have it for a while as it was a special order. oh it was 290 bucks. but if it the right tool i will be happy.
Edited by jorstad brothers - 04 Feb 2017 at 10:16pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 10:11am
I had this tool made. It's well built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 11:07am
Lynn- that looks like it would be heavy duty! Do you know where that hole in the hollow shaft has to be positioned? I forgot to mark that when I took the 12 bolts out.
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 12:38pm
I see no mention of positioning the oil hole in the service manual. If it was mine, I would probably put it at a 3 o'clock or 9 o'clock location rather than just straight up or down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 6:07pm
Thanks, after closer examination it looks like it was probably about 9 or 10 o'clock. Will your socket work with the shaft poking through? Mine will only work with the shaft removed. May have to do a little remodeling to make it work better!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 7:21pm
Almost looks like a socket for  hub nut for a 4 whl drive truck,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 8:22pm
The OTC #1931 is for a 1997 to ??? Chev pickup I believe. Sorry no picture yet.
