Grinding Feed
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Topic: Grinding Feed
    Posted: 01 Feb 2017 at 5:33pm
Took this shot on Sunday. Might be a new favorite for me. That's my Dad raking corn into the mill.
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 6:05pm
we had a gehl 95 looks like a twin to yours it didnt seem to like ear corn and clumps of hay lol... but i did make pretty feed. i think we are going to go back to making feed cause they did better. then how they are doing on the co_op feed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 6:32pm
Reminds me of my youth.  We had a gehl grinder, no mixer, first we had to move a truckload of corn from the corn house, to the grinding room, shovel it through a 36" door, then shovel the pile back, then pull the little grinder forward, through the door, hook it to the D-19, then shovel it all through the grinder, and then shovel the ground pile back, and then move the grinder back.
When I was 15, I parked the D-14 with the bush hog and the heavy grille guard, aimed at the cinder block wall, down hill, put it in N, and went up for lunch.  As luck would have it, that damned parking brake , failed, and the tractor knocked enough of the wall down, that I was able to move the grinder over to the corn house...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:20pm
Planned Failure........I like that...
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:42pm
can still hear the ears hitting the hammers, didnt have ear plugs in those days
phil
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:45pm
as usual the old timers doing the work. Kenny L.
Edited by Kenny L. - 01 Feb 2017 at 7:47pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 8:34pm
Lol!!
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 9:16pm
    That is a great picture. Thanks for posting.    Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 9:51pm
That outfit sure looks good. I have ground a lot of ear corn in my time but with a red and yellow feedgrinder and a green and yellow one. I always enjoy grinding as the fresh feed has a good smell to it. Tom
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 11:47pm
all we had was a belt driven hammer mill, and would only feed it when we had hang overs! whew!
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 5:53am
Don't see pics like that much anymore. Looks good.
Ya cain't fix stupid.
saele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 5:56am
I have no picture, what am I missing, Thanks guys, in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 5:58am
When I posted my question the picture came in, so all is well.
Thanks
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 6:35am
That there ain't too bad a job while gravity is with you like that....climbing inside and carrying each shovel full to the feed auger ain't so much fun. I'll be grinding a batch this weekend.
Oldred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 7:15am
What kind of implement do you use to harvest the cob corn ? Some kind of modified forage harvestor or ?? Just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 7:47am
called an ear corn picker. some are mounted on a tractor and some are pull type units and some are self propelled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 8:02am
Like shameless says, a corn picker. Fairly simple concept. A set of rollers straddles the corn plant and they counter rotate and pull the plant down through the rolls as you drive forward. The plant fits through but the ear doesn't, so it pops off. From there it gets conveyed to some more rollers that "attempt" to take the husks off the ear, and eventually gets conveyed up an elevator to dump in a wagon you're hauling behind you.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 10:38am
'Bout every Saturday, got to drive the '67 Chevrolet Step-side to the corn crib and shovel a "jag" of ear corn in while dad did chores.  One of two things happened--he would show up and say, "Is that all the corn you've shoveled?" Or, "Thats way too much corn; I'm going to have to find some more bags!"  And off to the elevator we would go.  When the bagged feed came off the loading dock, he would put it in the truck in order of unloading--chicken, steer, hog so that no bag had to be lifted or moved more than once.  R. Musgrave
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 11:36am
That's a good picker used there. Notice there is very little shuck left? That's the way to feed cattle in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 12:12pm
These are the most common machines used yet. There were many tractor mounted pickers also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 12:13pm
You notice the "Old Timer" was on the ground and not way up in the crib? That picture wasn't taken with a selfie stick! lol
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 1:00pm
Well, someone has to climb up on the top to kick down more corn!
Allis Express participant
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 1:23pm
Only one question... was the parking brake even on???? LOL, good story though. Big smileBig smileWink
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 1:28pm
Okay I see,
Haha next question.
Now what do you with the rest of the corn stock at that point ? I would guess turn the cattle out on it or plow under for a type of green manure ?
Thx Mark
PS: We don't see any of this way up north !
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 1:56pm
You can bale them for bedding, turn cattle on them, plow them under or just leave them be and notill through them in the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 5:12pm
We had a picker just like that Jim. Pretty good one.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 10:24pm
I had to post a couple of videos here.  Here is the corn picker we used for many years.  Now don't shoot me for the tractor, it's just an illustration of a picker in use.
[TUBE]http://youtu.be/S1P4SsHKbV8[/TUBE]
[TUBE]http://youtu.be/E-hCT0yVaRc[/TUBE]
Also here is picture of my dad grinding corn.  Always had some extra and would just pile it on the ground over winter when the cribs were full.  Kept very well if gone by spring.  All the bare cobs were where deer had eaten.  My dad was pointing at that to get me to record all of the corn they had eaten.
[TUBE]http://youtu.be/TtFeeF6XM9o[/TUBE]
Finally, to make up for the first videos, I'll show how we harvest the corn since there aren't any cows at home any more.
[TUBE]http://youtu.be/_QlKnnaWJko[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:46am
Enjoyed the videos, thanks for posting.  We had very little corn around here before 2000, since the newer varieties and warmer climate has come around corn and soybeans are fast becoming the main crop.
Edited by saele - 03 Feb 2017 at 7:48am
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 8:58am
Ground a lot of ear corn for cattle. Used a new idea picker just like that one. Used the 180 with year around cab on it. Ground corn for around 150 head of cattle we were feeding out so ground often. Used a bear cat 950 grinder mixer then later a New Holland 358 grinder mixer which we still have. Used to also fill a trench silo with ground ear corn every year. It worked very well and kept good cut down on labor. And yes we piled some corn on ground and ground it up over the winter. Just grind shelled corn out of bin now. Easier and quicker. Those pictures bring back lots of memories. When you were young that kind of work kept you in shape. Running a hammer mill also made you deaf. Really enjoyed those pictures.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 12:30pm
I used to have a Gehl 95 with a hay table. It would make the smoke roll on 100 HP tractor when you fed hay in.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
