Help on 7060 |
AllisandGleaner
Topic: Help on 7060Posted: 25 Jan 2017 at 8:04pm |
Looking at a 7060 black belly tractor with power shift the tractor has around 4,000 hours on it and it will hit all forward gears but won't go backwards will go in reverse and nothing will happen. Fellow said that ever since he had the tractor it had a weak reverse and one day he had a man running it cutting corn stalks and a pile got up and the man tried to back it up and got it stuck on the stalks spinning until it wouldn't spin no more. Any pointers in what the problem may be before I get it and tear it to pieces. Thanks
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2374 |
Posted: 25 Jan 2017 at 8:37pm |
Linkage would be the first thing I'd check
MACK
Posted: 25 Jan 2017 at 8:46pm |
Unhook shifter at valve, then manually move linkage to reverse. Start tractor and see if it will back up. If not, it is a complete rebuild. MACK
