AC 5040
kwmck1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwmck1959 Quote  Post ReplyReply Direct Link To This Post Topic: AC 5040
    Posted: 20 Jan 2017 at 5:57pm
I was recently given a AC 5040 and I have oil/water mix coming  from an area behind the starter. When I pulled the inspection plates off the bell housing it was filled with this oil water mix....any ideas how or why it would have gotten in there ? I took out one of the bottom 4 bolts underneath the housing and the mix drained out but not sure what to do next about cleaning and removing all the mix from around the clutch/ pressure plate without separating the tractor....any thoughts or suggestions would be appropriated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 6:28pm
Oil and water, or oil and coolant?  I'd check the dipstick, or drop the pan, and see what the bottom of the motor looks like first...
