need help with an Allis chalmers wd
hopper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper Quote  Post ReplyReply Direct Link To This Post Topic: need help with an Allis chalmers wd
    Posted: 12 Jan 2017 at 5:40am
i am having problems with my early allis Chalmers wd. i think it is the governor. i have to start it by putting my hand on the carb for the air intake. i got the tractor as a bucket of parts sitting outside and ive gotten it this far so i am making progress on it. i got another radiator from another tractor and it is a pressurized one and it will over heat if i have the cap on sometimes should it be a non pressurized radiator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 5:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 5:49am
can anyone tell me how to do the photos right i messed the others up.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 6:28am
Make sure your choke is closing all the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 7:17am
Make absolutely sure the choke plate is all there. Sometimes the spring loaded flapper valve is g-o-n-e.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:20am
Set the picture height to 480 and width to 640 when uploading and then they won't be bigger than the screen when the text is a readable size.
Gerald J.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:46am
I'd run a compression test, you might have a blown head gasket.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:51am
you should be fine with either a pressurized or non-pressurized radiator. That shouldn't make I overheat. You've been given good advice by great mechanics. Check what they suggested then post back what you find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 12:26pm
Here ya go............
jkoby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoby Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:20pm
Could you have your choke rod connected backwards?
We accidentally had the bracket the connected the choke rod to the choke plate flipped 180 degrees. Drove me nuts for a while. I couldn't understand why the tractor would only start with no choke and would require choke to run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 5:24am
