Need info for L59 mower on my B
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Topic: Need info for L59 mower on my B
    Posted: 07 Jan 2017 at 10:55pm
Bout a used woods L59 mower for my B. I have everything installed now. It came with two belts. They had one on the deck and one driving the deck. I have now figured out its supposed to have one large belt. Does anybody know the number for this belt ? And also a diagram for installing the belt ? Thanks.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 3:10pm
Do a search for a woods L59 manual. Should help alot. If not pm me with your email and I will send you a copy.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 3:22pm
A Woods 59 IS only one L-O-N-G belt!---BUT if it be a look alike ,(cant remember the name right now) then it would use three belts.---IH used these on cub tractors before they went to woods. thanks ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 4:57pm
It is a L59 .   so your saying it does not use one long belt ?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 5:04pm
He means a L59 uses just one long belt. Maybe post a pic of your mower!
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 5:07pm
I know theres a woods 59 that's right hand discharge and a woods L59 left hand discharge. That's what I thought you meant. Mine is a woods L59 not a look alike. . Anyone know the number for the belt ?
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 5:44pm
The Woods L59 belt part # is 3652.
You can go to the Woods web site and request any manual, they will email it to you free, I have done it. Very helpful to have the manuals. Go to        www.woodsequipment.com/manualRequest.aspx
You can also get most any belt from JayDee at www.JDV-Belts.com    The JD # for the L59 belt is B225K.
Bill B
Edited by wbecker - 08 Jan 2017 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 5:49pm
Thx Bill !
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:06pm
Oldways, hope you re read my post, I wrote 365 for the Woods number, I missed the 2, the Woods # is 3652.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 7:36am
Since these belts are so expensive, some people have adapted the mower to have 2 belts, one to drive the main pulley and one or even two to drive the blades.  They usually put in a tensioner pulley for the blades.  Does yours have an extra tension pulley on it?  Got any pics of it Lee?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 8:00am
The Woods belt is pricey; can obtain great quality belts less expensive. The generic belt is a B225; that is, B style, 225 inches long. Check wit your local NAPA, Tractor Supply, or JayDee Belts (link below)
http://www.jdv-belts.com/catalogs.html
You can obtain a PDF copy of the Owners Manual from the Woods site (link below. I can also email you a copy if you PM me your regular eMail address.
http://www.woodsequipment.com/
These mowers require careful alignment of the deck and tensioner pulleys...and proper tightening of the belt for the single belt to work good because of the many twists it has when installed. If your has been properly modified fot two belts, you should have fewer twists
Edited by GregLawlerMinn - 09 Jan 2017 at 8:03am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 4:33pm
 Bought a belt online that has lasted quite well and wasn't bad on price. It may have been from V-belts.com or something like it. I was told to make sure I get a kevlar belt which I did. As I said in a previous reply you can find the manual online or I will be happy to email  it to you also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 5:23pm
Someone did modify it and add an idler on the deck. I'll try and post some pics tonight. It was in pieces when I purchased it and wasn't mounted to a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 5:29pm
Got the manual thanks guys for all the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 9:59pm
Trying to get pics up
Edited by oldways - 10 Jan 2017 at 10:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 10:00pm
Just got a photobucket account. No idea if this'll work. Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 10:28pm
http://s1320.photobucket.com/user/bairdsllc1/library/Mobile%20Uploads
This page was generated in 0.238 seconds.
