B won,t move |
ihscout
Joined: 12 Jul 2011 Location: Northern CO Points: 147 |
Topic: B won,t movePosted: 06 Jan 2017 at 12:50pm |
Ok. I was out plowing with my 1940 B. Only 22 inches of snow and -4 degrees. I got stuck and almost got out. Anyway, The machine's rear wheels quit turning while in gear. The PTO still operates for the loader bucket. Any ideas of what to look at when I head back out into the tundra?
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
rpropst
Posted: 06 Jan 2017 at 1:06pm |
3 things come to mind. None of them easy. Transmission not going in to gear, ring gear and pinion, or final drive gear or shaft.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 06 Jan 2017 at 2:35pm |
If the brakes work try stepping on one at a time if it's in a final drive you should be abel to limp to the shop by holding the broken side brake
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 06 Jan 2017 at 8:16pm |
I hate to say it but it looks like my favorite is not too good.
Thinking of what is said above - and they are right on - perhaps a loose nut on the wheel? In any event wish you the very best of luck on this. Let us know how it goes. Good Luck! Bill Long
AJ
Posted: 06 Jan 2017 at 8:40pm |
Check for frozen water in trans.
Can't fix stupid
Dakota Dave
Posted: 06 Jan 2017 at 9:51pm |
Carefully tow it back to the shop. Remove the PTO housing and pickup your spider gear cross pin out of the bottom. Hope nothing else is broken. Good luck
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 06 Jan 2017 at 10:45pm |
Or teeth ripped or worn off axle or hub or both.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 07 Jan 2017 at 7:20am |
If you were going from forward to reverse repeatedly the problem most likely will be just below your shifter stick. I would guess it would be in the side plate assembly but could just be a worn fork that let the slide gear set free from the gear that would move the tractor. Pictures of the side plate assembly with forks and picture of the grooves the slide forks have to be in. In the picture the gears are in the neutral position which is my guess to your problem. If it is the case you would have to examine the side plate for the cause. ![]()
Edited by Dick L - 07 Jan 2017 at 7:25am |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89151 |
Posted: 07 Jan 2017 at 9:00am |
I vote for Dicks plan. I have seen the shift lever pop out and get stuck in 2 gears or neutral.. Does the shift lever "FEEL" like it goes into all 4 gears ? .... Hard to believe you broke gear teeth in the finals.
wbecker
Posted: 07 Jan 2017 at 9:12am |
Do what Dick said,
then if it's not the shifter assembly, it's probably what Dakota Dave said. |
pumpkinman
Joined: 20 Jul 2011 Location: S.E. Michigan Points: 252 |
Posted: 07 Jan 2017 at 12:45pm |
STRIPED REAR WHEEL CENTER OR CLUTCH IS SHOT [WILL TURN P T O SHAFT BUT SLIPS UNDER LOAD ]
ihscout
Posted: 07 Jan 2017 at 6:25pm |
I'll be checking it out tomorrow and will let ya know
