rear wheel spacing g for plow
old diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old diesel Quote  Post ReplyReply Direct Link To This Post Topic: rear wheel spacing g for plow
    Posted: 02 Jan 2017 at 3:48pm
purchased a front mounted plow for g allis. need to know spacing or a diagram for rear wheels. thanks ahead.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 4:29pm
You need the G operator's manual and the plow manual probably also the implement manual. I have just uploaded those to my web page server in a private directory.
The operator's manual is 37 MB download at http://www.geraldj.networkiowa.com/Trees/Allis%20Chalmers%20G%20Owners%20Manual%20(TM-4A)0001.pdf
The implement manual is in two parts 22MB and 8 MB at: http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf
and
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf
Basically they call for the rear wheels to be spaced 40 or 44 inches but the right front to be 26" out from the center so it can be in the last furrow plowed and the rear wheel in the furrow just plowed. There are many drawing and pictures in these manual. I have a couple G plow manuals too, but the implement manual is more detailed and covers other things you need like the hand lift.
Gerald J.
This page was generated in 0.081 seconds.
