Tested Horsepower of U or UC
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Tested Horsepower of U or UC
    Posted: 01 Jan 2017 at 10:18pm
Has anyone ever put a stock U or UC on a dyno?  I keep thinking that they had more power than reported on the Nebraska Tests.  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 11:46pm
Uc had more draw bar pull with continental than um engine.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 12:32pm
Our UC 52 hp. Hi compression pistols 1/8 shaved off head.
turbocharged
Harold (MID MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harold (MID MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 3:58pm
Our 37 U tested out at 38 HP on the dyno at last years show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 4:36pm
Thanks.   I assume the U was stock.  Were the high compression pistons in the UC stock or some you had modified?  My UC has 14.9X30 tires on it so it tends to power-out when I pull it at our club pulls.  Of course it scoots right along in first gear with those big tires.  Even though the engine is in good shape, maybe some shaved off the head would make it spunkier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:48pm
The pistons in our UC are cast iron the pistons I took out came about 3/8 below the top of the sleeves the ones in there now are about 3/8 above the sleeves + I had .125 thou. off of the head it is a bear to pull over tdc. The tractor belongs to my son now he has kindof lost interest but I would like to put aluminum pistons w/ even higher compession i think they would have to be made.
turbocharged
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 10:31pm
I have a set of alum. pistons that are above the top of the block. they are new.
This page was generated in 0.089 seconds.
