D 14 cracked head???
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: D 14 cracked head???
    Posted: 02 Jun 2010 at 10:08pm
I have a D 14 that I'm slowly fixing up. It has been in the family since it was new. For about ten years now, that I can remember anyway, when we'd change the oil we'd get a little antifreeze. not much, but it was some. Dad was never worried about it and thought it was the head gasket leaking a little or coolant leaking past the liners. I  removed the valve cover to set the valve lash about a year ago and noticed quite alot of sludge on the valve cover and valve/ rocker area. I said something to Dad about it and he said that it was always gunked up like that ever since he could remember. "His Dad was the one who bought the tractor new."  I meticously cleaned out all the sludge and reinstalled the cover. Last week I thought I'd remove the cover and take a look. To my surprise it was gunked up pretty good again and I noticed a little "green liquid" puddled here and there. I knew it wasn't good, but was hoping it was maybe just the freeze plugs/ casting hole plugs leaking. I was hoping they had just corroded through or something. I cleaned everything up reall good and started the tractor and let it run with the valve cover off. After it began to warm up a small trickle of antifreeze started between the exh. and intake valves on the two middle cylinders. ....... :(   My ? being, can this be fixed???  How much  $ would one expect if it can be fixed?? Also, what kind of damage has been done with antfreeze leaking this long??? It could have been leaking for years. The tractor was used fairly often and the oil was changed at least twice a year. What are your opinions?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 3:22pm
heres a pic of a head  that belzona has kept the water from blowing out the no.3 exhaust port.
Edited by mlpankey - 03 Jun 2010 at 3:26pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 7:33pm
mr.panky..where do you get the belzona?you must really like it.when ever i overhaul a 45-d,before i ever run the engine,i add a bottle of the ford cooling system addative that is used in the 7.3 ford powerstroke.supposed to make for a better heat transfer from sleeves and prevent water to sleeve erosion
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 7:36pm
Warm it up and dump some stop leak or water glass in the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 7:42pm
The leak isn't coming from the core plugs and just appearing to be coming from between the valves?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 7:44pm
Its hard to do that when you port through to the water jacket steam hole. The belzona works when the uh-oh happens it  is also resistant to methanol if your doing the bump port to turn the air into the cylinders on Siamese intake runners.  I purchase it from Belzona River States 303-D Beltline Place,SW#313 Decatuar AL 35603 office phone number (256) 355 1560
 Ps that head picture above I ran it 2.5 pulling seasons before the bottom end of the motor let go with the belzona repair in the no 3 exhaust port. Dover cylinder head a company known in this area for fixing cracked cylinder heads wouldn't attempt to repair it when they saw it . my testimony . It fixes more stuff in my shop than I through away cause it cant
Edited by mlpankey - 03 Jun 2010 at 8:00pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 9:33pm
I would suggest looking at the core plugs too.  My 58 D14 always lets some coolant come out when I change the oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 11:14pm
I'll try replacing the core plugs first and see what happens. It really looks like there's a couple of cracks though. Are the plugs just standard freeze plugs? Is is something a guy can get at the local parts store or do they have to come from a dealer?
Thanks!
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 10:26am
Standard "freeze" plug available at any auto parts store. I cleaned the casting good around the hole and added a thin film of gasket sealer to mine. Don't know if it was necessary but didn't think it would hurt any.
This page was generated in 0.095 seconds.
