G262/G230 Gasket set |
Baldwinm
Topic: G262/G230 Gasket setPosted: 28 Dec 2016 at 2:59pm |
Where can I get a full gasket set for a G-262? Diesel sets seem to be plentiful but gas sets are hard to come by without paying over 300. Can I get a diesel set and then just get a separate gas engine head gasket or are there other things different? Engine is a G-230 with a G-262 head
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2080 |
Posted: 28 Dec 2016 at 3:14pm |
I needed one for a D 15 engine for a fork lift which is different than the tractor D 15 engine gasket set. After calling my 4 AGCO dealers that usually can get most of these items and could not find a set, I went to my local NAPA and asked. They ordered it in and the search was over. So I guess I'm saying, try NAPA (ours is very friendly with these older engines so your NAPA my not have the same results). Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
Baldwinm
Posted: 28 Dec 2016 at 3:28pm |
Napa does have a full set but its for a diesel. They only have a head set for gas engines as long as head gasket is the only thing different ill just get both of those.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 29 Dec 2016 at 7:48am |
Try Minn-par parts, they have many hard to get AC parts if Norm Meinert can't get it. 815-238-4506
Baldwinm
Posted: 30 Dec 2016 at 7:24am |
Any input on the diesel set vs gas sets?
Travis(NE)
Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
Posted: 04 Jan 2017 at 8:25pm |
Off the top of my head the only different gaskets would be the head and intake/exhaust manifold... The front cover or adapter plate may be different depending on application... Is the water pump on the block or head? You could also try www.agcopartsbooks.com and compare the gaskets on a D19 as it is the only tractor that used the G262 and the D262...
Baldwinm
Posted: 05 Jan 2017 at 11:30am |
Adapter plate and front cover will be coming off my wd45 230 diesel engine
Travis(NE)
Posted: 05 Jan 2017 at 7:51pm |
The inner gasket is probably the same between the D230 and the G262, but I doubt the outer gasket between the plate and the cover is the same. I'm not sure you can use the D230 adapter plate with the G262 governor without some modifications...
