Allis WD Factory Top Link bracket
eversr007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eversr007 Quote  Post ReplyReply Direct Link To This Post Topic: Allis WD Factory Top Link bracket
    Posted: 26 Dec 2016 at 8:41am
Hi new to the forum and was going to see if anyone knew where i could come up with an AC WD Top link bracket.  It clamps on the rock bar if that is the right name.  The bar that goes between the two lift arms that has a pin hole going horizontal for a top link.  I can only find aftermarket which I don't want.  If anyone could help I would be very grateful.  Or if anyone has one they would sell.  I have checked with all the local salvage yards around me.  Here is a picture to help visualize.  Thanks
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:44am
I have one of those I believe
Can't fix stupid
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 7:25pm
'Factory'?
I don't think Harry Ferguson's patent for the 3-point hitch ever allowed AC to make them... at least, not until the patent expired... but I'm pretty certain that others probably got away with it...
Can any AC historians shed light on this?
FWIW, I made my own top link bracket, mounts off the diff cover bolt pattern, but it's higher than the rockshaft, to yield more versatile geometry. I posted a picture on the forum here somewhere...
Ah, here it is...
http://www.allischalmers.com/forum/uploads/2752/top_link_from_side.jpg
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 7:34pm
Those top link brackets bring pretty good money if you can find them. They're kinda hard to come by.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 7:54pm
They were used on snap coupler ac bush hogs. The height adjustment goes to there. We have one on the 45. Might have a spare someplace.
Edited by Daehler - 26 Dec 2016 at 7:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:20pm
I have one for sale. Send me a PM if still looking. Thanks Matt
 Just bumped the post back up in the classified section
Edited by Matt (Jordan,MN) - 27 Dec 2016 at 1:34am
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:24pm
With my father I was pleased to sell the WD for the life of the unit.  During that time - except for after market attachments - we did not have a "factory" three point attachment.
Now, they are readily available from many of the sponsors here.
Dave, That is a very good job on that three point hitch.
Good Luck!
Bill Long
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:34pm
I like your design Dave. Gets that top link up more where it should be. Hopefully those studs are strong enough. Fair bit of stress can occur there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 9:27am
I made a very very crude one (quick and dirty) that is "U" shaped with a hole through it, just slips over the rock shaft. It is at a lower position on the rock shaft. Made from 1/2 inch thick steel plate about 3 inches wide.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 10:55am
X2
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 12:56pm
I made one out of 1/4" thick wall stainless pipe and welded a piece of channel onto that and the whole thing slides over the rock shaft.  It hangs down when not in use and is out of the way.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 8:32am
Yes   ac did make a snap coupler to 3 point adapter
WD's and 45's B's and c's and a few red ones , ALLIS EXPRESS also
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 6:19pm
the pic he is showing is the factory top link bracket that bolts around the rock shaft, they were made and sold by allis for the sc to 3pt adapter that came after the production of the wds but was allis, those toplink adapters are pretty pricey they were usually close to 200 bucks on ebay , but haven't been looking for a while mabe a year or so
Post Options Post Options   Thanks (0) Thanks(0)   Quote eversr007 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:05am
I forgot to get back on here and look for replies.  It was supposed to email me notifications if anyone replied.  I've been busy building a house and finally started to relax and just remembered to check back.  Already been 3 months.  Found one on a tractor but haven't picked it up yet to see if it is worn really bad or not. I'll pm you Matt.  Might still need one.
Ac51wd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac51wd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 1:23pm
I'm looking for a factory top link bracket for a wd if some one has one please call me (573)645-8875
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 1:35pm
What Bryan and Dustin said...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac51wd Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac51wd Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:10pm
do you know of any?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 3:40pm
I have one I'll sell.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 6:17pm
I would have several of the original Allis top links. (like in top picture) The part no for the cap that is the back is 332380. The part no for the front is 332379. Would have some top link holders that are not Allis but work well. PS Will sell. 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 11:30pm
Yeah, it looks a little light, doesn't it?  Let's run the numbers:
Six studs @ 26,000lb tensile strength each= 156,000lbs. 3 point load in excess of 5000lbs results in front wheels in the air.  If that load were entirely on the top link bracket, that's only 833lbs each stud... or 1/30th of the studs' tensile strength.
The highest load I can apply, is a pallet on my 3-point fork attachment.  When applying a 5000lb load to the 3-point, the top link is only subjected to 500lbs or so...
...but let's say it's 1000lbs... divided by six... is 167lbs... or a safety factor of 155.
...Let's say it's just the top two studs actually taking any tensile load... that's 1000/2=500lbs of tension on a 26,000lb fastener, for a safety factor of 52.
I think it'll be okay.  Ten years, and it hasn't failed yet...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac51wd Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 10:04pm
can you send a picture and price
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac51wd Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 2:09pm
I'm interested would you be able call me?
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 6:43pm
We have a factory 3 point bolt on link on one of our WD45's but it is not for sale.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
