hydraulic fluid /gleaner combines
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic fluid /gleaner combines
    Posted: 22 Dec 2016 at 9:37am
I have an F and an M2 that both need a couple leaky hydraulic lines replaced. What type of fluid do they take? Will any transmission fluid work or does it have to be a specific type? I don't want to go to the dealer and pay their prices.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 11:32am
Dextron III or whatever the latest and greatest Dextron oil is.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 2:59pm
Thats what I needed to know, thanks.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 11:56pm
Dexron III, also sold as just "Automatic Transmission Fluid"
Do not Get Dexron 6 (VI) it is full synthetic and will trash seals.
If you own a Gleaner, you will be using the 10 dollars off a 50 dollar purchase coupon you get in the mail for your local Napa for a 5 gallon bucket of Dexron III. :) dont buy in quarts or gallons, 5 gallons is what you need.
Later Gleaners have went to 821XL (like in the 90s) but the Dex has high heat stability, good cold weather flowability, and excellent cleanliness, I personally like it, just gotta keep leaks in check.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
