B/C magneto and tuneup
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: B/C magneto and tuneup
    Posted: 19 Dec 2016 at 3:16pm
I am giving the tractors some TLC. Would like confirmation of my assumptions with the spark timing. It has the magneto.
My C flywheel has a F mark on it. I can't find a C mark.
If I am running 1200 rpm, using a timing light, the F mark should light up centered
in the timing hole?
Is this F mark at 30 degrees BTDC?
The magneto has no varying advance, F is centered same at 600 rpm or 1200. Correct?
The magneto's impluse coupling retards the spark by 30 degrees when hand cranking?
That means the start spark happens at about TDC?
Thank you
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 5:17pm
You are correct .
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
