7060 black Trans oil reading over-fill
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: 7060 black Trans oil reading over-fill
    Posted: 14 Dec 2016 at 10:27pm
Like the earlier 100 series AC. Tractor (170,180,185,190,200), will the newer 7010-7080's power director and/or power shift transmission compartment seals go bad, thus allowing rear-end (differential) oil to transfer into transmission housing? Or, is there another culprit (hydraulic pump, valve, etc) that will do the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:04am
Yes, there are seals that can cause oil to transfer. Usually in hid. pump but not always.
Hope some day they will make a seal that will never fail.     MACK
