Radiator Foam
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Radiator Foam
    Posted: 14 Dec 2016 at 5:07am
The Foam seal around my 190xt radiator has fallen apart. Suggestions on what to use to seal around the tin work to keep the air flowing through the rad?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:14am
best would be closed cell foam.  I think the box lumber stores sell it as draft stop foam for windows, doors and sills...
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:37am
You can try that expanding spray foam, though it's hard to do a neat job with it. Remember that a little goes a long way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:38am
I'll have to check it out.
I need to put it back together to see how much clearance I have to fill in.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:40am
Umm, that would stick to both surfaces and then the hood could not be removed?
Charlie
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:48am
One of the electronics repair places I used in the past would use expanding foam but they sprayed it into a bag inside the box. The plastic bag made it come apart later and the foam made the box into a perfect shipping container for my part.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 6:06am
I was thinking a thin piece of plastic as well.
Would a piece of 'Saran Wrap' stick to the hood.
Put Saran Wrap' on, then assemble.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 6:11am
A good big box store may have  the thick foam backer that window installers sometimes use to fil BIG gaps,if not found, that rectangular selfadhesive  door foam will work. If you need extar extra height ,just put 2nd layer on top.
I would NOT use spray foam. too messy, too uncontrollable,it's a nighmare in a spray can !!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 6:39am
I used pipe sleeve insulation for my 7045. For the most part, I cut it in half length ways into various lengths and shapes. For a little tidier job, I could have used adhesive or double sided tape or something, but mostly I used zip ties. Seems to work fine. Guys on here say the kits are still available at Agco, but no dealers around me. Not one of Allis's better traits in my book.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 7:19am
Tell me about it! When the siding people showed up early to side my "new" used freshly moved house I had wanted to seal up a few gaps where it set on the foundation before they sided. I was in a panic when I came home from work and they were already at it. I grabbed one of the two cans of Great Stuff or whatever it was called. I tried to get the cover off the first can and I broke the tip off. I had foam flowing out all over myself and ran to the house to try and seal the gaps with this volcano flowing everywhere. That ran out real fast. I then grabbed the second and last can and opened that up much more carefully, but it wouldn't shut off and again I'm running around like a mad man trying to seal gaps. Ruined my jacket and I'm sure the siding people were really impressed! Star
Wink
I am a Russian Bot
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 7:29am
I'd see if Ago has it, redid a 7045 foam a couple years ago and got the stuff from Agco it was right and will be good for 35 more years and it looks good.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 8:37pm
The new AGCO foam I bought in 2010 for my 8070 is crap now....kinda disappointing for $75.Aint been oily or nothing.No expansion left to it and it sucks out of place ending up hanging down front of radiator.Maybe 300hrs
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 9:29pm
I used the foam out of my old tractor seat from my 8010. Works great.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 9:36pm
For years, I used 3" memory foam. It worked great, right up to the point when it caught fire this fall.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 12:39am
I found in the local hardware store they have foam for sealing around air conditioners, it comes in like a 3" x 3" x 36" piece along with a smaller size available (1-1/2" X 1-1/2" X 36"?)depending on the hole to be filled.  I used it on a 7060 and my D-21.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 3:59am
I save old couch cushions, and when I need foam for anything I cut it with an electric knife the size I need. i've  used this thru the years for the tractors too! they also work good for making new seats too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 4:41am
Thanks for the ideas
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 6:37am
When I worked at the Allis dealer the shop foreman's wife did upholstery work and he used an electric knife to make the foam pieces from the left over foam or old couch cushions. Worked good.
Wink
I am a Russian Bot
