7060 shifting
summertime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote summertime Quote  Post ReplyReply Direct Link To This Post Topic: 7060 shifting
    Posted: 08 Dec 2016 at 7:52pm
I have a 7060 powershift that is starting to grind when shifting into high or low range. What do I need to adjust?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 8:59pm
Snap ring has come off spool in inching spool. Need to pull valve body to fix.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2016 at 9:16am
A-C came with an improved design, eliminating the troublesome snap ring that breaks. Whenever I ran into one of them, I'd position things where they belong and spot a small blob of weld on the spools end doing the same thing as the snap ring. Problem solved permanently. If you want to spend the $$$ to update the parts to the newest, have at it.
This page was generated in 0.104 seconds.
