8 lug rim interchangeability between Brands?
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: 8 lug rim interchangeability between Brands?
    Posted: 02 Dec 2016 at 1:34pm
Hello, i need to roll a IH 504 tractor off a trailer into my garage. ( I know its the wrong color...)  but its a cheap loader tractor and my winter project. It has one bad rear rim and I just need to swap it out with a good tire/rim so I can roll the tractor around temporarily. will an allis 8 lug wheel fit on there off my WD? are the 8 lug patterns pretty universal on rears?  i dont want to find out the hard way. Thanks!
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 2:44pm
Measure the center hub size and distance between a couple bolts and that should tell you.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 2:50pm
Also check the lug bolt size. Btdt. It should work just fine tho. Should be an 8 on 8 with a 6" center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 5:20pm
It should
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:02pm
I put JD on my D14,  fit fine.  Of course I painted them orange first!
This page was generated in 0.170 seconds.
