D15 II 3 point?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 II 3 point?
    Posted: 01 Dec 2016 at 8:02pm
Can someone post a pic of the correct 3 point arms on a series II, D15?I have two of them, and they both have two holes near the end of arm that implement attaches to. The manual doesn't show them. I wondered what they were for? Thanks Tracy
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 10:39pm
Not sure about 3 pt, but on SC the two hole are used for lifting front mounted cultivators (both sides).  A bracket pulls a rod that raised the cultivator is mounted there using the two holes.  Later styles uses the hyld system to raise the front mounted cultivator, but used the RH lift arm (two holes) to mount a depth control rod.  Again on SC, not sure about 3 pt.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 4:44am
Not sure if this shows the detail you need but had this one on my phone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:59am
Butch, mine have two holes near the ball. Not sure what they were for. Wondering if they cam from another tractor? Tracy
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 10:55am
Here is what mine look like.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:10am
Dennis, that is the way mine are. What were the holes for? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:12am
 I do not know.
Thanks & God Bless
Dennis
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:15am
Move the vertical / adjustable lifting arms to the outer holes for greater lifting power but shorter travel distance.
Gary
 < ="" ="text/">setTimeout("waitForPageRender()",5000);
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:42am
Tracy..mine also has the one hole...which I use for depth control chains for certain jobs...I think they were intended for the leverage discussed above....they used the same setup on D-10 and 12 which has different geometry...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 4:02pm
 Here is the pictures from a operators manual and parts manual.
 So the 3 point on my tractor has 2 extra holes for whatever reason.
Thanks & God Bless
Dennis
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 10:00am
Here is how mine looked before I restored it.  Looks like the others on this post...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 6:54pm
Dennis, that looks my series I, without the draft control. The series II has the heavy one piece cranks. Also note the position of the lifting arm pivot hole location on the manual and real tractor photo. Definitely two different arms. JMHO, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 9:12am
Yep, the top picture came out of the series II operators manual. The series I manual didn't have any information about a 3 point hitch.
The bottom picture is out of the 1966 D-15 parts book and that's the only one listed.
Thanks & God Bless
Dennis
