Using a starter solenoid on a WD45
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: Using a starter solenoid on a WD45
    Posted: 01 Dec 2016 at 2:38pm
I'm wanting to run my WD45 starter with a solenoid rather than the starter-mount button and lever-rod setup.   (Why? Im custon building a dash and just want to)
Can I remove that switch and wire in a heavy lead to a big solenoid?
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 2:56pm
you will need to replace the switch contact lug with a stud so you can attach a cable to it but yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 8:57pm
Find a starter for AC 100 combine, it was made that way.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 10:47pm
Don't know when I'll get back up to the farm, but I did this to my 1940 C and it works just great.
Don't know if you can tell what I did by this picture.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 11:49am
I'm going to do this to my WD45 also, so when I get up I will get a pic and some description of what I did and send it to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 1:47pm
Don't know what TED did, but the original starter has a cam connected to the push rod and the cam pushes the starter contact in... I pushed the cam in manually, then put a 1/4 inch PIN thru it to hold it in place so it could not backoff the switch. Did this on 4-5 tractors.. Only had one that the cam backed off a little and lost contact.. Had to REDO the pin to hold more pressure on the switch.  .......... I think I actually had to make a new cam a little larger so I could get the catch pin into place.
Edited by steve(ill) - 04 Dec 2016 at 1:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 6:19pm
NOW that you mention it steve..... I made a new cam piece so that the cam was larger and kept the starter contact IN ALL THE TIME.  Then just wired in the solenoid and used a key to start it.  SIMPLE!!
THANKS Steve......my memory isn't what it used to be........be what? LOL
