D-15 power steering pump
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Topic: D-15 power steering pump
    Posted: 28 Nov 2016 at 7:59am
Working on a 15 that I bought, trying to get the power steering working, after several attemps I took the pump apart. One of the gears are broke, bearings are good. My questions can you replace the shaft and the gear from another pump, can you buy a new gear? Are there different pump manufacturer that the tractors use, even though the mounting is the same? Are the internals the same on a d-17 iv or 19 that you can use parts? Lot of open questions if someone can shed a little knowledge on. Thanks
Mo Allis Club member
Don(MO) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 9:56am
D15-I or D15-II, gas or Diesel tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 1:11pm
gas
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 1:36pm
Go to the AGCO parts website using this link and select guest and then search on D15 to get the part numbers. You can then call to see if the parts are still available.
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
