D 17 sires IV,,, help
Keith E View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Topic: D 17 sires IV,,, help
    Posted: 25 Nov 2016 at 9:26am
Problem is, when started up the lift arms will raise, and not lower. If anyone might know what is wrong and what I can do to fix it.
WD 45 peddle tractor2 WC speed patrols D 12, D12 sires3, 3 D17's 2 r diesel 1 gas sires 4, 2 200's 1 is for parts, JD 1020
4 WD's in the weeds
JOHN N/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:42am
Follow your linkage under your lift lever and see if plunger is stuck,spray with wd40 and see if it moves,probably stuck out
D-15IIG65,D-17IVG67,D-17D58,620
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:56am
Is it Snap-Coupler hitch? If yes, this is normal and the arms need a lot of weight on them to make them go back down. Three point hitch the lower links are usually enough weight to pull them back down unless the valve is stuck. There is another thread on here with pics that show how to fix the sticking valve.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 10:50am
Move the height position control lever or the traction booster lever and watch what they do underneath. See which valve isn't moving and take a pair of channelocs and see if you can get in there and wiggle it. If you are lucky like I was it will pop free.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 2:37pm
Okay, it is not snap coupler, sires IV has a factory 3 point, I had a 6' box blade on it and was coming down really slow at a fast idle, then had a 6' brush hog and same thing, and now it starts raising as soon as I start it up, there is a screw on the back side that will let it down, but screwed all the way in, it starts to raise up, going out to look it over again. Oh, and one cylinder has started leaking now, checked fluids and they were low, so I put some in it to the full mark, and nothing changed.
4 WD's in the weeds
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 3:58pm
Sounds like the piston in the controls is sticking, one nearest fender in the valve stack if memory serves. Mine w/ 3-pt was barn find that reportedly had not been in regular use for many years. See if the piston is tracking the linkage when moved for/aft, if not lower arms and with tractor not running, remove rear cap via allen heads. Use brass or hardwood dowelling to reach in and move the piston, spray with your favorite go juice, move piston opposite way with control lever and repeat. Good time to inspect the "cintered" vent material on the back of the cap to make sure it is not plugged. Also follow all linkages as mine had a broken weld on a bracket where someone had forced it before I bought it. Re-welded, freed up the piston and arms operated smoothly.
Then get ready to have fun with the lifting pistons, packing leaks if it has been sitting. Have been told A-C replaced cylinders back in the day, with lift cylinders from the 190 as more robust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 6:21pm
Okay, I took the little cap off the back of the piston and can see it is working from the control leaver, and still the same thing???
4 WD's in the weeds
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 10:31pm
Best to replace the original lift cylinders with the newer style from salvage 180, 185 etc. You'll save yourself a lot of misery. Yes, you can "fix" the originals but they will leak again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 8:51am
so, the leaking lift cylinders are what is causing it to lift as soon as it is started?
4 WD's in the weeds
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:25am
No, leaking cylinders are not causing it to rise.  The problem is not with the valve, so screwing in the valve makes no difference.  The problem is with the traction booster LINKAGE that contacts the valve.  Look under the console and you will see this linkage (see picture below).  The cam on the right side is the culprit.  It should not be pressing against the valve when the traction booster is disengaged (lever pushed forward).  The cam should also move back and forth freely.  Over 40 some years, that cam has rusted to the bushing it rides on.  While some penetrating oil will help it, the best solution is to remove the cam, knock the bushing out, clean it out and then coat with anti-seize, then re-install it.  I have done this to all of my tractors which have this set up.
This post should be in the knowledge base section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 4:47pm
Didn't mean to imply the leaking cylinders caused the lift to rise. I was just commenting that the original cylinders on the Series IV tractors are a poor design compared to the ones on the later tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 6:15pm
Thanks for the info Rodger, and to DSeris4, I have checked all that was suggested, I see where that one pivot point cold be froze up, and I worked it for a bit and took the back side off and no change moving that piston back and forth, i am guessing I will have to take it all apart to make sure it is moving freely and no broken welds up under there where I can't really see.
4 WD's in the weeds
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 8:28pm
If you loosen the nut on the fingers pivot bolt, and then turn the bolt head until the bolt can rotate freely, leave the nut loose, and the finger (I don't call it a cam) will be free and will work just fine. No real need for disassembly any further than that unless you want to. Both rear hydraulic levers must be FORWARD in order for the arms to stay down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith E Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 6:06pm
Great news, I did as DrAllis said and it seems to be working now, it raises and lowers as it should, but bleeds down pretty quick while just moving it in and out of the barn, could this be caused by the leaking cylinders? And thanks for all the help Thumbs Up
4 WD's in the weeds
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 6:42pm
The leaking cylinders are certainly contributing to the settling down of the hitch with a load on it. But, it's also likely the hydraulic valve has some of the settling coming from internal leakage. This was fairly common on three point hitch models. Anyway, the rear lever closest to the seat is the "depth control". Move it almost clear to the rear and the hitch can't settle down like it currently is. That's what it can be used for.
