Allis G oil pump question
Tinco2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tinco2 Quote  Post ReplyReply Direct Link To This Post Topic: Allis G oil pump question
    Posted: 24 Nov 2016 at 11:21am
I am currently restoring An Allis G. I am in the process of replacing the oil pump and noticed that there are two types of gaskets. One has the cut out for the oil ports and the other has the gasket material around the oil ports. The tractor service manual shows the one with the gasket cut out around ports installed but the manual that come with the oil pump has the one with the gasket around the ports installed. help im confused
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 7:06am
You should be able to download a service manual here.
http://www.foleyengines.com/resources/product-guides-forms-tags/continental-l-head-overhaul-manual
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:07am
I have an Allis G B C and CA shop manual on line at: http://www.geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
It is an 11 mb download. I do have a Continental manual in paper in my library.
I suspect the oil pump gaskets depend on the details of the buyer of the engine whether Massey Pony, Allis G or other uses. The blocks of the Pony and the Allis don't interchange. But most all the other parts do. The gasket may also depend on when the engine was made.
Gerald J.
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:17am
Perhaps I don't understand your question.
Page G-19 in your manual has a picture of the oil pump breakdown showing the gaskets. Beyond that, I can't help. New to the G myself.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 10:09am
both my Allis Manual and my Continental "N" manual show the same orientation  #6 & #8 are your gaskets with #8 going against the block
do you have something different? A picture of what you have might help us-
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 10:37am
Anything I have shows the same sequence of parts.
Gasket #8 against the block, Cover #7, Gasket #6 and  and Body #14.
This page was generated in 1.214 seconds.
