Gleaner E and All cylinder
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E and All cylinder
    Posted: 21 Nov 2016 at 10:03am
Been doing some research trying to find new cylinder bars for the E and A2 but I'm not coming up with anything short of calling an AGCO dealer. Are there any aftermarket suppliers that still offer them? Does AGCO still offer them? Looking to do corn, beans, oats, wheat and rye with them.
Thanks. Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:07am
E-E3-K-K2 are all the same. The A-A2 is an orphan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:08am
Google Trimpe Hard Surface Bars and St. Johns Welding.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:48am
I bet St. Johns would make something for you. Even if you had to send in an old one (which I doubt you would).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 12:20pm
So the A uses different ones then the E and K?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 12:51pm
The A/A2 cyl is wider than E-K's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 12:54pm
The A-A2 had three wide straw walkers. The C-C2 had four wide straw walkers. These two machines were based off of each other so to speak. The E-E3-K-K2 also had three walkers, but there were an inch or two narrower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:29pm
I have a set for A-A2 that I cut ever other tooth out then built back up that I would sell cheap. Went to F2.    MACK
