180 Drain Plug Fitting
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 180 Drain Plug Fitting
    Posted: 18 Nov 2016 at 12:59pm
My old 180 has started putting hydraulic oil in the rear so I've read to connect the drain outlets of the hydraulic and the rear together.Problem I'm having is finding a fitting that will
match up with the threads of the hole in the rear.Anyone know what I need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 1:36pm
Gary - drill and tap your existing pugs to take common pipe fittings then buy plugs when you split it later to fix it right.
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 7:10am
Was hoping I could find something to screw up into the rear hole, the front plug is pipe threads.Doubt I'll ever fix this tractor the transmission has problems and is pretty rough but still runs good and all I do with it is load and unload hay bales,plus being a gasser it starts easy in cold weather.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 8:34am
 i had to get a plug from AGCO i think the plug was about $25. take your existing plug out and drill through the plug tap the hole with 1/4' pipe thread and use a close couple fitting in it. puit a 1/4' to 1/2' bushing on the close couple nipple before putting you elbow on.  using a smaller elbow restricts the fluid to much. you wont have any pressure in this line just gravity flow to get the fluid to transfer.
