Power director shifter
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Power director shifter
    Posted: 17 Nov 2016 at 5:44pm
The part number in the book is 228050. Is this still available new? This is the part that the brass collar rides on.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 7:10am
The last I knew they were available. Call your local Agco dealer.      MACK
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 9:08am
Does show to be available yet Lon, part number has changed a few times.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 11:28pm
If I followed the superceded numbers properly, its still available, and should be under 100 bucks, probably around 75
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
