|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Allis 200 |
| Post Reply   |
| Keith E   Silver Level   Joined: 15 Oct 2014 Location: oklahoma Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Topic: Allis 200 Posted: 14 Nov 2016 at 11:17am |
   I had a leak at the PTO, took it apart 2 times, put it back together 2 times and it worked, but didn't take it apart far enough to fix the leak, 3rd time take it a part, had to have gear and bearing pressed off and on and put it back together the 3rd time and now the PTO don't work, and don't know why. Need some help. | |
      WD 45 peddle tractor2 WC speed patrols D 12, D12 sires3, 3 D17's 2 r diesel 1 gas sires 4,  2 200's 1 is for parts, JD 1020 4 WD's in the weeds | |
| CAL(KS)   Orange Level   Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Nov 2016 at 11:42am |
   coupler fall off?
     Me -C,U,UC,WC,WD45,190XT,TL-12,145T,HD6G,HD16,HD20 Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 | |
| Keith E   Silver Level   Joined: 15 Oct 2014 Location: oklahoma Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Nov 2016 at 11:45am |
   And that would be way inside at the other end of the long shaft? Or the one right inside the when I take the lift arm and housing off? | |
| CAL(KS)   Orange Level   Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Nov 2016 at 11:59am |
   if you have the 2 speed pto there is a coupling inside the hydraulic reservoir and another in the rear housing
| Keith E   Silver Level   Joined: 15 Oct 2014 Location: oklahoma Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Nov 2016 at 12:10pm |
   Yes it is 2 speed, when I stated it back together I could feel it go into the splines deep in side, and I stated the long shaft in there before I put it back together, the splines deep inside have to line up before the line up pins on the housing, but I could be wrong, could I try the PTO with just the long shaft before I try to put the housing back on?
| Keith E   Silver Level   Joined: 15 Oct 2014 Location: oklahoma Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Nov 2016 at 12:17pm |
   Oh, and let me thank you for your time and help, I may need more
| Keith E   Silver Level   Joined: 15 Oct 2014 Location: oklahoma Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Nov 2016 at 6:56pm |
   Okay, after looking deep in side and seeing the coupler and using a ling metal rod and flash light, yes I could see the coupler and feel that it had been pushed forward, and looking it over for hours,,,,, on the left side of the trans housing is a short leaver that looks like it needs a linkage rod to it, and lightly tapping on it with a hammer then looking bak inside and seeing that it moved the coupler towards the back so it would engage the pto, the lite came on,, this is a manual shift for the pto, and before I did all this I could see inside and see the pto turning, but when I put it back together the last few times nothing at the pro out side the rearend, so I am so happy as to have it fixed and not leaking.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
